1971 VW Type 3 Fastback Restoration
- evan.fraser.274
- What model do you have?: T3 FB, T2 Bay, 63 T1
- Has thanked: 23 times
- Been thanked: 9 times
Hi all
Here are the first pics of my restoration effort.
So far I am - with the assistance of the team at VDubTech - having the motor taken back to its original state (twin carbs with the right block and distributor) as the current one is a T1 subassembly with a single side draft carb. I have also put 4 new tyres on her as the old ones were a death trap.
I notice some surface rust and started a minor strip of the interior which turned into a full strip of the carpets and sound-proofing. Sadly the rust is a lot worse than I thought and the driver's side floor pan is rusted through; so I will be calling on the help of an expert welder.
Fortunately all the parts I need are available internationally (very little locally due to the import nature of this model - VWSA stopped making the type 3 here in 1969 apparently and I have an import from Rhodesian ex UK)...or am I wrong?
Next steps are:
1. Have the new motor installed with a new clutch and distributor, cleaned-up tin and the right air cleaners. Oh and make sure the heat-exchangers work properly...I enjoy warm feet
2. Get the front steering and suspension sorted; their is excessive play on the wheel end and the general state of the ball joints and tie rod ends is bad
3. Get all the rust sorted out (all the fenders are badly rusted on the inside)
4. Get her resprayed once the rust is sorted
5. Finish up the interior (fix the inner workings of the seats and replace the hood lining); the door panels and seat coverings are excellent still
6. Re-chrome the headlight reflectors and rear bumper
And that should be about it for now
Next steps are:
Given enough time and money, anything is possible...
Re: 1971 VW Type 3 Fastback Restoration
she looks good. Sounds like its going to keep you busy for a while
- Single Port
- Has thanked: 13 times
Let me know if you find ball joints cheap.. Need for my 66
- GERHARD73
- What model do you have?: 1974 1600 BEETLE
- Been thanked: 7 times
Hi Evan,
Good idea to have her repainted prior to attempting to do the interior, as you would have to remove the rear windows to do the hood lining and the re-install them.
She looks beautiful.
WILL WE EVER KILL THE BUG?!?!?!?!?
1974 BEETLE 1600
VW BEACH BUGGY
2010 2.0 TDI VW KOMBI
2010 1.6 TDI VW POLO 6
1974 BEETLE 1600
VW BEACH BUGGY
- jolas
- Has thanked: 393 times
- Been thanked: 173 times
lovely solid looking car
- evan.fraser.274
[quote="brianj"]Let me know if you find ball joints cheap.. Need for my 66
You can import them at a cost of $35.95 each (upper part number 311405361B and lower part number 311405371C; I assume the b/j for the '66 are the same as for the '71). I'm sure you've seen that Volkspares want R792/R741 for the same thing. The problem is that shipping is $80...but I'm willing to entertain splitting the shipping cost with you if you want to order yours with mine The only problem right now is that - with the exchange rate - it works out the same price to buy them from Volkspares
- Single Port
Thanks for the research!
- evan.fraser.274
[quote="brianj"]Thanks for the research!
Let me know if you want...seems I am going to have to order mine after all and Volkspares have no stock (with no idea when they will be getting)
- evan.fraser.274
A quick update: Car has been stripped and is in the process of being painted (compliments of VDubTech)...have ordered all the necessary replacement parts and she is waiting bodywork completion before the front suspension gets some attention...one thing I have learned is how expensive a hobby this can be
looking good.... and yea, toys arent cheap
- Been thanked: 539 times
Good to see yet another Fastback coming back to life.
Yes, to fix it right, costs, but the joy in driving her, is priceless.
You doing a magic job there, following the thread with excitement.
- What model do you have?: Mk1 Golf
- Pushrod
- Has thanked: 141 times
- Been thanked: 100 times
I don't have faith in that white rust conversion stuff that turns purple/black. The rust always seems to come back. I rather strip all the rust and use red oxide primer.
