vw beetle IRS rear suspension
johanmarais
What model do you have?: 1990
Has thanked: 28 times
Post by johanmarais »
Morning all
From what year model did the VW Beetle have vw beetle IRS rear suspension and was it available here in SA?
I've only seen swing axle's before and never a IRS.
1990 2.1 Caravelle (Auto)
Has thanked: 235 times
Re: vw beetle IRS rear suspension
SA Beetles never had IRS
dixtoy
Has thanked: 60 times
Been thanked: 37 times
Post by dixtoy »
Is a swing axle beetle not technically also IRS? Just not with loose shafts and CV joints
1959 Beetle (Lindor)
1975 Fleetline panel (Ouvrou)
1971 Westy (Gypsy)
johanmarais
Thanks Pine, is there any aftermarket way to convert it into IRS and (if so) do you maybe know if its locally available?
johanmarais wrote:Thanks Pine, is there any aftermarket way to convert it into IRS and (if so) do you maybe know if its locally available?
I suppose anything is available, but perhaps it would be the easiest to get a 1302 or 1303 donor Beetle. The biggest problem will probably be to source an IRS gearbox, the whole conversion process is explained here: http://www.bajaclub.co.uk/PDF_Documents/IRS.PDF
you could also use trailing arms from a 944
Dixon, you are right, but in VW circles, the semi-trailing arm version is referred to as IRS and the one we know as swing axle.
In reality though, they are both independent (IRS)
dixtoy
Post by dixtoy »
My one beetle was made IRS as by the previous owner, not sure what they used. Will take some picks tomorrow. My box came out of a Fugly kombi and changed by Pierre to stage1 with CV joints
1971 Westy (Gypsy)
johanmarais
Thanks for all the info(s)
I'm playing around with the idea of a Subaru swap with Subaru gearbox.
I've done an EJ25 swap onto a Beetle box before on a trike and I'm in the planning stages of a new build and would like a Subaru swap with gearbox swap into a Beetle.
johanmarais
Will I be right in saying that the 1302/1303 is the Super Beetle?
johanmarais wrote:Will I be right in saying that the 1302/1303 is the Super Beetle?
That would be correct, yes. Not to be confused with the South African 1600S curved windscreen Beetle though
dixtoy
Post by dixtoy »
Here is one pic I have with me now
1971 Westy (Gypsy)
johanmarais
Pine wrote:That would be correct, yes. Not to be confused with the South African 1600S curved windscreen Beetle though
Thanks Pine
dixtoy wrote:Here is one pic I have with me now
Thanks dixtoy, that photo helps allot.
So what should I look for if I'm browsing the classified sites?
dixtoy
Post by dixtoy »
I would think if you find a scrap type 4 you could use its rear suspension and weld it on to a beetle pan with some modified brackets. What area you in? I have a 412 rolling body with a gearbox that we could talk about should you want to go that route. I'm in Heidelberg GP.
1971 Westy (Gypsy)
johanmarais
dixtoy wrote:I would think if you find a scrap type 4 you could use its rear suspension and weld it on to a beetle pan with some modified brackets. What area you in? I have a 412 rolling body with a gearbox that we could talk about should you want to go that route. I'm in Heidelberg GP.
Vanderbijlpark, not that far from you.
Hope these pics help
