Hey gentlemen
Any body have a template for the glass size (SAFARI) as well as back window of a S/C ,59 MODEL
Doekle
Safari window glass template
- jolas
- Has thanked: 393 times
- Been thanked: 173 times
Re: Safari window glass template
I will check wrt the rear window - I wonder if its the same size as the rear hatch of an early split bus, I might have given it to someone else though, will double check ...Doekle wrote:Hey gentlemen
Doekle
- Merlin
- Has thanked: 20 times
- Been thanked: 39 times
Nope. It is tapered, like a barndoor's.jolas wrote:I will check wrt the rear window - I wonder if its the same size as the rear hatch of an early split bus
I may be interested in a template too... I shall need an interim glass, until such time as I'm able to source an original one.
- jolas
cool will check - i think that I gave it to sean though ....
