Tyres
freddiebooysen
What model do you have?: 1972
Been thanked: 47 times
Re: Tyres
Post by freddiebooysen »
That is a brilliant idea I also just saw a post on Facebook where the guys recommend 165/80 r15
Unfortunately bee is not rolling at the moment will have to take tyres and pay for them will check if they will exchange later if I take it back
Re: Tyres
Or go buy one tyre and if it doesnt fit properly, keep it as the spare.
The last thing you want it a 40yo spare tyre that pops after 2km...
sean
Has thanked: 63 times
Been thanked: 227 times
Re: Tyres
Post by sean »
Did you phone around substantially? It's not so ideal that you are going to use a tyre with a smaller diameter either now.
I recently bought a full set of 165/80R15's this year but they did cost quite a bit more than the ones you mention.
freddiebooysen
Re: Tyres
I did and actually did a compare on diameter with 185/65 R 15 and they are more like the originals diameter wise. I think the problem is just these are a bit wider and they might hit on the sides when turning.
But will keep you guys posted once they are on and rolling.
Rowan
What model do you have?: 1967 Beetle
Re: Tyres
Post by Rowan »
The 165/65/15's are the ideal tyre but they are a lil more expensive and harder to find. At the moment on my beetle the 195/65 rub slightly not major. if i was using the 195/65 for so long the 185/65 should do.
" Don't gain the world and lose your soul...Wisdom is better than silver or gold " - Bob Marley
Has thanked: 45 times
Been thanked: 208 times
Re: Tyres
Post by Dawie »
Around to 60's Porsche warned about the dangers of using tyres wider than rim width in rearward-weight biased vehicles, and especially if using swing axle suspension-(356).
Problem is tyre goes "trapezium shaped" when looking from front or rear. (Short line of trapezium is rim width and long line tread width.)
When cornering near the limit, or swerving to avoid an obstacle, contact area suddenly changes to now mostly making contact near sidewall area. (Because of trapezium shape). Causing sudden tailswing.
Going the other way- (slightly wider rim than tyre), did not cause problems in tests, and even helped in some situations. Although, in off-road conditions, sidewalls could be more exposed to damage.
If going small diameter low profile tyres, also decide if you will be happy with higher fuel consumption and noise during highway conditions...
Using too wide tyres on a light front end can be dangerous in the wet- (aquaplaning). So Porsche went to wider rear rims and tyres at the rear. Overall diameter is kept similar by using lower profile of wider tyre at rear, so tyre height stays same as smaller width fronts.
Rowan
Re: Tyres
Post by Rowan »
So i bought the 185/65 tyres and this is how they fit on the rims. Pic of rim on the beetle is how it looks fitted but note the wheel nuts are not tightened in the pic thats why the tyre looks abit skew.Once fitted on proper and test driven will update.
freddiebooysen
Re: Tyres
Fitted mine as well no test drive yet
Rowan
Re: Tyres
Post by Rowan »
I have driven the bug with the new tyres on and i can report no rubbing at all. Perfect fit.
freddiebooysen
Re: Tyres
Greate news thank you. Will report on mine as well soon should be fine though.
