Late Bay window rebuild
2l 16valve
What model do you have?: 1974 kombi
Post by 2l 16valve »
Busy with a late bay window panel van and before it goes to panel beater in jan I have been stripping it.
The front door aluminum trims are damaged and the window guides broken. Can I buy these new somewhere?
Also the rubber kits that are sold, how complete are they?
Will need front widescreen, both front doors, sliding door, rear window, engine comparment and tail gate rubbers.
Project looks a bit daunting as some stuff is so brittle a skeef look makes it fall apart.
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Re: Late Bay window rebuild
Post by Terry Phillips »
Rui should be able to help,he is on the forum or Tony.These things are not cheap and dont buy the local rubbers they are kak.
ja, there will be a few choice vloek woorde along the way, thats for sure, but keep the final picture or goal in mind.
Those window kits are available, and as Terry says, not cheap. Local window rubbers do work, but it is best to import good quality stuff that is actually
made to fit the door or window.
Tony has been bringing in some bits recently. Or Rui (calooker), Jacques in PE (splitbusaholic) might also have stock.
Wolfburg West is an option some of us have used, and their quality is good.
Exchange rates, import tax, duties, etc might bring on very loud curses :shock:
But good luck and post pics :hangloose:
And update your location on your avatar/profile so that we know where you are
