1962 T1 resto cal project
Jdt1976
Has thanked: 116 times
Been thanked: 90 times
Re: 1962 T1 resto cal project
Post by Jdt1976 »
That looks good.
I like the attenion to detail.
fourier
Has thanked: 31 times
Been thanked: 37 times
Post by fourier »
Excellent job! Your car is clearly built to a very high standard.
I see you are using the harder 78 durometer gearbox mounts from Wolfsburg West. I want to go the same way with my car, but don't know by how much (if any) they increase the noise and vibration inside the car. I know your car is not driving yet, but do you have any experience with these mounts?
What did you use for the front gearbox mount?
(o= i =o) (o\ ! /o)
62RestCal
What model do you have?: 62
Post by 62RestCal »
Hi Fourier, yes i really didn't want a solid mount and think that polyurethane is also too hard and not sure if they last. In the front i'm using an original style rubber mount and a lower brace like in the photo, will let you know how it pans outImageImage
fourier
Post by fourier »
Thanks for the info.
I'd be keen to know how your mounting set-up works out. I'm looking for a decent compromise between too soft (original mounts), and too firm (urethane/solid), without transmitting too much noise and vibration into the car.
Great build, love the detail! Keep the pics coming.
(o= i =o) (o\ ! /o)
62RestCal
Post by 62RestCal »
Image sound deadening and insulation going in
WOW!!! Thats great work. The car will sound solid and sit in the sun nice and cool!
62RestCal
Post by 62RestCal »
Doors are done and roof liner done, windows going in tomorrow.ImageImageImageImage
62RestCal
Post by 62RestCal »
So glad i kept all the old window trim, on the right is before and left is after aome good cleaning and light rubbing. The old trim is fitting into yhe new seals like a treat, much easier than fitting after market trim!Image
krikey, that looks good - nice work!
62RestCal
Post by 62RestCal »
Thanks Tony, I am pushing to get it finished now, as you know the motor is also done, and i'm glad i did it in that order because i am itching to start it up!!
62RestCal
Post by 62RestCal »
Windows fitted, the rear quarter windows were the trickiest, but all went well, was only about a PG13 process, just a little bit of swearing involvedImageImageImageImage
fourier
Post by fourier »
Nearly there. Awesome build!
(o= i =o) (o\ ! /o)
Alex20
What model do you have?: 1969 VW 1600 Baja
Post by Alex20 »
62RestCal, I love this build! The attention to detail is inspiring, my only question is why didn't you go with single piece front windows to get the complete Cal look? I actually use thus thread as a reference to people to what standard I'd like to build a car
Wentzel
Been thanked: 13 times
Post by Wentzel »
Looking good I love the roof lining it looks very nice.
Sent from my JAZZ using Tapatalk
Oxyboxer Project
Wentzel
Post by Wentzel »
Double post sorry.
Oxyboxer Project
