The roof has been repaired with a few kilo's of body filler which we have started removing.....can anyone say ching ching
Looks like the two week simple respray is going to end up being a 6 week fight which i will win. We have two weeks left, hopefully. Then I start with mechanical s which i think is also going to be fun. I know of either a bearing or brake component failure on the left rear as its making a funny squeaking type noise after its been driven for a while.... so the first job I will be doing is removing all brakes and bearings and replacing with new. The motor was apparently done about a year ago so for now I only plan to redo all the vacuum pipes and wiring which is in a bit of a mess currently and there is an oil leak which i need to trace and that needs to be fixed and then i will take it for a tune and a check over. I will also be cleaning and coating the undercarriage and then sorting out suspension, heater system (pipes mainly which are held on with wire). Then the interior........think it will be done by September?
One of the depressing patches of body filled about 5mm thick on the roof.
