Steering stiff after King and link pins replacement ,is this normal?
topdjinlondon
What model do you have?: 1975
Post by topdjinlondon »
Hi guys ,just wanted some advise on if it's normal for the steering to be very stiff after the king and link pins were replaced
Been thanked: 487 times
Re: Steering stiff after King and link pins replacement ,is this normal?
I wouldnt think so. The bore is supposed to line up between the two bushes, forming a straight line which should keep it smooth.
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Post by Terry Phillips »
Close your eyes and get a good hammer and give the bush housings a few smacks. If the bushes where not reamered with a guide then they will be tight as Tony says.
My 2 cents worth.
topdjinlondon
Terry Phillips wrote:Close your eyes and get a good hammer and give the bush housings a few smacks. If the bushes where not reamered with a guide then they will be tight as Tony says.
My 2 cents worth.
Not sure how the job was done ,also adjusters were fitted on the same day ,but I don't think that is the issue ,
Is there any thing else I could do other than using a hammer ?
Been thanked: 539 times
If the car is drivable, they will come loose,
If not, you may have to heat them so that expand, and they should be looser when cold.
Just watch out for rubbers and seals.
topdjinlondon
retrovan wrote:If the car is drivable, they will come loose,
The car is drivable but its not very safe to drive like that because you try turn the wheel and it doesn't respond straight away and when it does you can't correct it quick enough
topdjinlondon
Also the old owner has summited the yellow form and I have only 10 days left before I need to roadworthy the car and put it in my name ,it will never pass like this
Chardivw
Oil Seal
What model do you have?: 78 kombi 2000l
Facebook: Snowater photography
Has thanked: 12 times
Been thanked: 15 times
Post by Chardivw »
They are not going to drive it at roadworthy. If it has no play it will pass
Terry Phillips
Zambia
You dont need a roadworthy to register the car in your name only thing is you wont get the disc until you provide a roadworthy certificate..Gauteng not sure your side.
topdjinlondon
When I get there and drive up the ramp they will see how tired I am from driving it because the steering is Kuk hard and it's a effort to drive it
topdjinlondon
Ya same down here but I don't drive it often so god knows how long it will take for it to loosen up
Jdt1976
Has thanked: 114 times
Been thanked: 90 times
Post by Jdt1976 »
Terry Phillips wrote: Thu Apr 13, 2017 5:00 pm You dont need a roadworthy to register the car in your name only thing is you wont get the disc until you provide a roadworthy certificate..Gauteng not sure your side.
That's correct. You can go Tuesday and register it on your name and when you done roadworthy you go back to the licence office and then get a disc. In JHB you have 21 days to do the change of ownership.
Terry Phillips
Zambia
I dont mean beat it to death,some times the pin catches on the bush and leaves a high spot and a few smaks with a copper hammer or brass punch sorts it out. If that dont work then you have a problem re do the whole thing again.If you dont have the right tools to start off with then you will have these problems and the workshop manual is of no use to you either on this one,so now you have to make a plan with what you have.
Good luck hope you get sorted.
The problem you will have if you strip it and ream it straight, the high spots will get cut, and then you have more play then you need.
If you loosen it up by hammer, or heat, and jack it up, and let the family take turns to turn it lock to lock, you will have a good setup for a few thousand K's before having to do it again.
Or, you start again, and spend an extra grand for a full length reamer, and another couple of hundred for the bushes, and do it again.
The choice is a personal thing, and we can not tell you which way to go,
you asked, we told, now it up to you.
Good luck
Down in CPT you can register the car in your name without roadworthy. You will only be able to get the license disc once you have roadworthy and only then are you legally allowed to drive the car.
I just did exactly that. Bought a car, registered it into my name in Dec without roadworthy and this week I finally went back to get my license disc after the roadworthy went through last week.
