1978 Baywindow Project (Picture heavy)
- Has thanked: 45 times
- Been thanked: 208 times
Re: 1978 Baywindow Project (Picture heavy)
Reason to use distributor from aircooled T3/t25 shape combi and avoid the wbx 1.9/2.1 type-
Aircooled distributor- 23 deg centrif advance- (designed for 200deg C max head temp conditions)- add 7.5 deg initial = 30.5 deg total
Watercooled wbx distr- 28 deg centrif advance (designed for 110 deg C max temp). Wbx appicaton uses 5 deg static + 28 = 33 total.
If used in aircooled engine and set to standard 7.5 static- total will be 35.5 degs.
Obviously the wbx distr will add more performace if used on an aircooled engine while the engine has just been started and still cold. When at operating temp it will knock to pieces especially at coastal altitude because of over-advancing. At Jhb altitude one might get away because of thinner air/ 17% power loss. But still not ideal, a proper aircooled distributor advanced by 2.5 degs or whatever for 2000m altitude (and retarded back before driving to lower altitude), might still be better.
Timing advance required is affected mainly by 3 things- rpm, load, and cylinder head temperature.
All new petrol engined cars have knock sensors and also adjust timing to match engine temperature.
Knocking- (over advanced timing), = kiss of death to any engine. Like hammers hitting inside combustion chamber.
The wbx distributor could however be modified to have a similar advance curve as the aircooled type. But this is not a job for a lazy guy, lots of testing and redoing required to get this right.
If we use wbx distr on aircooled engine, to be safe we could set max total advance by strobe to 30 degs, but idle will then be at 2 degs, resulting in power loss and increase of consumption under most conditions.
brucet
- Oil Seal
- What model do you have?: '78 2.0 Executive
- Has thanked: 72 times
Today I continued with the interior by finally fitting the shelves I bought a few months back. Unfortunately the person who sold them to me didn't mention that the passenger side shelf's brackets had all rusted or fallen off so fortunately I had a donor shelf I could use. I also had to make some brackets up.
My daughter also fitted a dream catcher to the mirror
Next up I have to redo the rear suspension as it is sitting very nose down when we drive her
Jason from German Steel Toys also sent his guys around again to fit electronic ignition. They don't usually do house calls but my bus wouldn't start due to the condenser again so he helped me out yet again. The end result is a massive difference in performance and she now starts without hesitation on the first click! Can't wait for the next road trip!
brucet
- Oil Seal
We will be traveling to Vaalplasie again on the 12th to spend the day. Will be leaving Randparkridge at around 10am if anyone would like to join us in convoy.
brucet
- Oil Seal
Adjusted the rear suspension by one click. It's a little lower than what I wanted so I may adjust front and back up a little one day. It drives, surprisingly very well though.
Nothing like driving around listening to UB40 at full blast though!
Hopefully this week the next job I will be doing is fitting the number plates and license.
brucet
- Oil Seal
Good news!! The kombi has passed roadworthy. Now a few more hoops to jump through and she will finally be in my name!
spicydave
- Oil Seal
- What model do you have?: 1973
- Has thanked: 7 times
- Been thanked: 15 times
Cool bananasbrucet wrote: Tue Aug 01, 2017 8:47 am Good news!! The kombi has passed roadworthy. Now a few more hoops to jump through and she will finally be in my name!
Always a good feeling when roadworthy and paperwork is done.
brucet
- Oil Seal
yes I can imagine. Cant wait for it to be done. Just waiting for the seller to take Police clearance into the licencing department in Nelspruit then as soon as that is done my registration can take place........
brucet
- Oil Seal
So this weekend we had a small celebration with some family and friends, at Vaalplasie. The kombi, which is yet to be named was brilliant. Drove at 100km/h most of the way without any difficulty, with 5 people and a bunch of stuff. Fuel consumption is way down. Don't know what it is exactly but usually we use about half a tank there and back. This time we used less than quarter of a tank.
There are a bunch of small things I still want to do but I think I am pretty much finished with her for now except I have to sort out an oil leak that was supposed to be fixed.
- freddiebooysen
- Been thanked: 47 times
Lekker man nice trip.
72 - Freddie Booysen
72 Bay - unnamed WIP
72 D/C - Blue abomination!
74 Beetle - BEE
74 Beetle - BEE
- Been thanked: 541 times
well done and clad you got it sorted.
Now for a longer run, why not push the limits.....
brucet
- Oil Seal
Funny you say that it in thinking of heading to Howick at the end of the month to collect a windsurfer from an aunt of mine. Not sure if that is wise yet.
- jolas
- Has thanked: 393 times
- Been thanked: 173 times
great stuff indeed Bruce, cool pics and a cool bus
