Fuel for a Splitty
Fuel for a Splitty
This may be a very silly question, but what kind of juice can i put in a '64 Splitty's tank. I have heard that LRP is worse than unleaded, and that i should try the latter instead?
- Single Port
- Has thanked: 13 times
have been using lrp, no problems.... wait for response from fig.. he probably has the most acvw miles on the new juice options
- fig
- Bus Driver
- Has thanked: 287 times
- Been thanked: 322 times
- vader
- Has thanked: 9 times
It depends on the valve seats? If your heads have the original type material then it should be fine but if your valve seats were replaced at some time with softer metal then thats when you will pick up problems with them..
