1975 Dropside !!
- Has thanked: 78 times
- Been thanked: 37 times
Re: First attempt at spraying !!!
Good luck with your first attempt.
Spray inside cab and engine bay first even if it is going to be the same colour.
Just my 2c worth
Just my 2c worth
thats actually some pretty damn good advice....
Good luck
Good luck
- Has thanked: 51 times
- Been thanked: 7 times
- Camshaft
- Been thanked: 107 times
Keep it up,.......as long as you have flatting paper you will get it perfect in time!
Goose and I promised ourselves that is what will be done with the next paint job,......we will do itourselves!,
Then we can blame only ourselves if itdoes'nt turn out as we want it!
Good job!
Regards Haans
Good job!
Regards Haans
- Has thanked: 193 times
- Been thanked: 121 times
- johanb
- Flywheel
- What model do you have?: '64 Bus
- Been thanked: 3 times
Hallo all,, all the best for the new year
Have S/C can been sprayed,, just want to see how the final product looking like,,
