That is a Fleetline, but that is not a Fleetline plate.
...and you are going to have endless strife trying to get that plate through police clearance.
"Understeer is when you hit the wall with the front of the car, and oversteer, the rear. Hp is how fast you hit the wall, and Torque is how far you take the wall with you."
As Merlin said. That is an obvious home made VIN plate, which won't be accepted by the police. Also, what is visible of the VIN says that VIN correctly belongs to a 1975 Fleetline single cab pick up. A Fleetline panelvan VIN would start with 2051.
