New beetle project
Bug_zee
What model do you have?: Beetle 70
New beetle project
Post by Bug_zee »
Hi all
New to the forum . I bought a 71 beetle recently. I have a list of things I want to do...but not sure where to start . I haven't driven on the road yet,except the day I brought it home when I bought it
Ultimately want to change the color (will post pics soon).
Things I need to do
1. Change tyres
2. Are brakes a DYI job ?
3. She starts ...but idle is erratic and sometimes cuts out
4.do I need to get it checked over by an expert for mechanical issues ....any suggestions who I can use ....based in Jhb
I can help myself mechanically but to an extent :D ....can do oil service and change brake pads ...but haven't ventured further than that
Been thanked: 487 times
Re: New beetle project
buy yourself the Haynes Manual and start reading. Then you can begin to tackle the small jobs - start with a full service and work your way up from there.
Brakes can be done DIY, but without the correct tools to size the pads to the drum, you wont have a good result and you'll end up with a care which is less than safe.
73type2
Has thanked: 141 times
Been thanked: 100 times
France
Post by 73type2 »
The disassembly and assembly of the brakes can be done DIY. Just follow the manual.I take my brake drums and shoes to a brake shop and the guy skims the drums and re-line the shoes for R500. I'd suggest you do the same.
Bug_zee
Post by Bug_zee »
Thanks ....will.get the book .... Is it available locally
yes it is. I bought mine originally at CNA, many years ago, but I've seen them on takealot
Bug_zee
Post by Bug_zee »
Thanks Tony ...only found the 1200 book on Takealot ....will check CNA and other book shops
coenraade
Post by coenraade »
http://www.autobooks.co.za/index.php?ro ... ct_id=2100
Bug_zee
Post by Bug_zee »
Thanks for the lead.... ordered book and already have it ..
Bug_zee
Post by Bug_zee »
Hi guys
How would I know if i had a twinport engine or not ??
I have this carb in my 71 beetle and is this a Standard carb
Been thanked: 539 times
Look where your inlet manifold goes into the heads, if it has a single entry, you have a single post, and if it splits into two pipes, then you have a twin port.
73type2
France
Post by 73type2 »
You could also do Google searches like "differences between Beetle single port and twin port". You'll get more info than you would want.
Bug_zee
Post by Bug_zee »
Need some advice please....i jacked up my beetle to put the back end on jack stands ...strangely as I was jacking up and when the vehicle tilted slightly left she started to leak oil from the gearbox ....definitely gearbox as it had a different colour and smell to engine oil.....what could have gone wrong ...as I had to put a drip pan under to control leak....it still leaked while I had it on the stands
axle boots are probably torn
Bug_zee
Post by Bug_zee »
Thanks Tony
John Alves
Has thanked: 3 times
Been thanked: 48 times
Post by John Alves »
73type2 wrote: Mon Aug 13, 2018 9:34 am The disassembly and assembly of the brakes can be done DIY. Just follow the manual.I take my brake drums and shoes to a brake shop and the guy skims the drums and re-line the shoes for R500. I'd suggest you do the same.
name of shop please
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
