Lwb buggy to Swb
dixtoy
Has thanked: 60 times
Been thanked: 37 times
Lwb buggy to Swb
Post by dixtoy »
Has anybody changed a LWB buggy body into a SWB. Specifically asking about the body, the pan is not an issue
1959 Beetle (Lindor)
1975 Fleetline panel (Ouvrou)
1971 Westy (Gypsy)
Camshaft
Been thanked: 107 times
Re: Lwb buggy to Swb
Post by Haans »
Dix,....I am sure if you are not worried aboutthe pan you will be able to tackle the fibre part of the job OR get a friend to assit,.....plenty paint brushes and latex gloves and powder for the itch!!
Jokes aside,.....make sure that you strengthen the cut area well,.....thats about it. Don't know much,....but we've done a few tricky little things.
John Alves
Has thanked: 3 times
Been thanked: 48 times
Post by John Alves »
you might want to consider doing a slightly longer version of a swb, (Beamish in Cape Town do a longer version) makes a huge difference when caring passengers etc.
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
Been thanked: 539 times
Dix, you need to work out which part of the pan was cut out, then cut out the same section only do a zigzag line and not straight to give you strength when joining.
Count the the body to pan bolts from the front on both body and pan and make the middle mark
Then count the body to pan bolts from the back and do the same, in this way you will see the section of pan cut out. mark a zigzag on a section of cardboard, and transfer kit using the bottom sill as your datum point.
Mark 4 lines, and cut and join.
Good Luck
dixtoy
Post by dixtoy »
Thanks all.
Fund a decent SWB body for a reasonable price and sold the LWB
1971 Westy (Gypsy)
73type2
Has thanked: 141 times
Been thanked: 100 times
France
Post by 73type2 »
That's a much cleaner solution!!
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Post by Terry Phillips »
Better plan there Dixon otherwise you where in for a few headaches trying to get thee cut so the 2 halfs line up again.Good luck and send us some up dates.
