Oil recommendation
Been thanked: 487 times
Re: Oil recommendation
64 Notchback wrote: Mon Oct 22, 2018 7:10 pm Guys please google "Royal Purple Synergy ISO 150"
Let me know what you think
I found
http://www.royalpurpleindustrial.com/as ... GY-PDS.pdf
Says that its an 80W90 oil, but there isnt a mention of GL4 or GL5.
Because of that, I'd be hesitant to use it in a car.
german
What model do you have?: none yet
Has thanked: 11 times
Been thanked: 7 times
Post by german »
I know on m cycles T4 for the wet clutch and gears but a 10w40 or 50. Being a big bore single it is a bit noisy and wonder if a 50 would be quieter?
The manufacturer recommends 40 but shell says 10w50
Camshaft
Been thanked: 107 times
Post by Haans »
And I thought I knew EVERYTHING ?????? ?
Now I know nothing!!!!
I guess its everyman for himself ????
Been thanked: 539 times
german wrote: Wed Oct 24, 2018 6:14 am I know on m cycles T4 for the wet clutch and gears but a 10w40 or 50. Being a big bore single it is a bit noisy and wonder if a 50 would be quieter?
It all has to do with mileage, if your engine has high mileage, then you can comfortably go to a 50, as the thicker oil will take up the extra clearance between the worn parts.
You can even add a thick additive or as the "Old Toppies" did it with and old worn out motor, is add gearbox oil and help the motor do an extra 100 000 Km more then it would have done before bearing knock.
Thats how they got the beetle motors to run perfect with a hell of a play in the crank movement.
64 Notchback
Has thanked: 78 times
Been thanked: 37 times
Post by 64 Notchback »
Tony Z wrote: Tue Oct 23, 2018 11:11 pm
I found
Thanks for the info Tony.
I think I will give it ago in the Sand Rail gearbox and see how it goes, although will probably not know if it is a disaster for a while.
My thinking is once the Rail is running is to drive it with the current gearbox oil for awhile and the change it to the Royal Purple and see what happens.
malcolm13
What model do you have?: 1964 Splitty
Post by malcolm13 »
Oil selection is about ambient temperature. The higher the outside temp the higher the temp your engine runs. The hotter the oil, the thinner the film between your bearings. South Africa has a hot climate, that's why they would say 20/50. It's the best grade for our conditions. I run an XR650 and wouldn't use anything lower than 20/50. People go with the OEM recommendation but must realize they're in Europe or Japan. Much cooler than SA.
Batman
What model do you have?: 1971 Beetle 1600 TP
Post by Batman »
Thanks guys, I bought some CASTROL GTX 20W-50 yesterday.
