the disc shouldnt move in relation to the caliper, so if it clears, that should be good enough. I'd say 1mm is fine, hopefully others can chime in.
The adapter will need to be trimmed down to clear. Easy on a lathe - your fathers lathe should work for this if he still has it.
Make sure you are using well fitting half thread bolts so that it can not move around in the hole.
Normally they supply you with a location bolt on the one side to stop the bracket from moving under braking.
If not, you can make a threaded tube and take up the clearance space around the bolt.
Donovan D
Has thanked: 149 times
Been thanked: 73 times
Post by Donovan D »
Progess has been slow, but its coming along nicely.
Very nice work, keep it up
Now that its summer again, the garage is a better place to bee....
really looks good
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Post by Terry Phillips »
All the pieces bits and pieces when it comes together you will be one proud man keep it up.
fourier
Has thanked: 31 times
Been thanked: 37 times
Post by fourier »
Looking good Donovan!
(o= i =o) (o\ ! /o)
cool :hangloose:
Donovan D
Post by Donovan D »
Some before pics.
These pictures were actually taken in 2015, the updated pics above was taken a year ago.
Progress has been very slow, but Im really happy with the work done.
Simmy
What model do you have?: 1978 Beetle
Post by Simmy »
Great work on the bodywork!
Although I'm not one to comment on speed of projects, at least progress continues to occur... And once it's done and looks amazing, then hardly anyone (including yourself) will even pay attention to that anyway.
Donovan D
Post by Donovan D »
A lot of work has gone into the body so far and its looking good.
Looks good, you can be proud.
What a differences a few hundred hours make.... :shock:
:D
Jdt1976
Has thanked: 116 times
Been thanked: 90 times
Post by Jdt1976 »
Good progress.
Are you going to replace the “J-Strips” that takes the rubber that seals the bonnet and bootlet?
Donovan D
Post by Donovan D »
Jdt1976 wrote: Tue Dec 04, 2018 12:42 pm Good progress.
I wasnt to fussed about it but now Im thinking I should try and get them on.
Are there any local places that sell these strips ?
Jdt1976
Post by Jdt1976 »
Not sure if someone local got them.
I get them from Virtanen.
https://restorationpanels.com/product/j ... and-hoods/
You just take the primer off at the places you going to weld so now after primer is the right time to do it.
