After that though, I think I can send parts off for final balancing and ceramic coating before assembly? Unless I am much mistaken, I don't think there is anything else internally which needs checking. As a recap, this is what's been done:
- Case has been mic'd, and cleaned up with the Dremel.
- Case plugs removed, threaded and prepped for full-flow set-up.
- Extended sump trial fitted and oil pickup tube prepped
- Bearings fitted and aligned with oil holes
- Heads CC'd and ported
- Valves lapped
- Geometry set on valves (almost)
- Deck height set
- Cylinders lapped into heads and case
- Cam and bearings fitted and degreed within 0.5deg
- Oil pump blue printed and trial fitted with cam
- Flywheel end play checked
- Distributor drive fitted and shimmed
