The exhaust studs will line up, but not sure about other clearances..
edit - this on my early bay, which is riding high at the moment...
Sent from my SM-G973F using Tapatalk
Fair comments both...Merlin wrote:Two thoughts...
1. You would have an uninsulated heat source directly below your sump.
2. Access to your sump plate will be next to impossible, making oil changes a nightmare.
