Has thanked: 143 times
Been thanked: 422 times
Flag: South Africa
Post by Tony Z » Wed Mar 27, 2019 1:22 pm
if your wiring harness is the Empi generic one, take it back. they have a bad rap for poor quality wiring and too thin insulation.
Your better bet would be to buy a harness for a Mk1 golf and extend the wires - they use the same colours as the beetle.
Wiring is always measured in mm2. To note though, 1.5mm2 wires are no longer 1.5mm2 in area. It began as a size to current capability, i.e. originally it took a 1.5mm2 wire to carry a 16A load safely. Todays materials are better so the same wire size can now handle higher current, but the "standards" were set, so today, any wire capable of carrying a 16A load is 1.5mm2 even if it actually only measures 0.75mm2
Maybe this is what you are seeing with the wires you bought from GHS??
Donovan D
Has thanked: 118 times
Been thanked: 57 times
Flag: South Africa
Post by Donovan D » Thu Mar 28, 2019 8:20 am
Thanks Tony.
The harness is one that Volkspares make up themselves and not an Empi one. The colours are not correct according to the online diagrams as they only have solid colours.
AlanH
Oil Seal
What model do you have?: '60Beetle, '70Westy
Has thanked: 52 times
Been thanked: 49 times
Flag: Germany
Post by AlanH » Thu Mar 28, 2019 9:16 am
Remember also that the old vehicles were 6V and subsequently the current was higher as well.
With 12V the current is lower and you can use thinner wire.
Has thanked: 25 times
Been thanked: 160 times
Flag: South Africa
Post by Dawie » Thu Mar 28, 2019 1:12 pm
Think wiring route was easier and shorter on older rhd beetles. From fusebox/switches/warning lights, loom towards the rear goes up via right upper pillar into roof. Then straight back down right rear pillar to engine, and rear lights.
"Things should be as simple as possible, BUT NO SIMPLER THAN THAT."
"If something can go wrong, it will go wrong" (Murphy's law).
Has thanked: 210 times
Been thanked: 440 times
Flag: Netherlands
Post by retrovan » Thu Mar 28, 2019 1:36 pm
Think only the brake light switch on the MC has to be extended for RHD.
Just remember that the old wires only had a few strands of thick copper in them, the new AUTO wire has ten times more strands, yes thinner, but as current is carried on the outer surface of a conductor, they have more surface area, so that why the wire is thinner.
1968 Fastback 2Lt.type4( Red)
2019 MeFusco Beetle Truck
Donovan D
Flag: South Africa
Post by Donovan D » Thu Apr 25, 2019 12:01 pm
Alrighty, just a bit of an update.
Did the brake lines, only need to do two more on the rear wheels, but can only do that once the drums are in place.
After bending all the brake pipes, except for the two in the rear, I managed to mess up the smallest and easiest pipe, the 200mm one also at the rear. :roll:
There is a tab on the chassis to secure something in place, I googled and couldnt find what needs to go there as I initially thought it was for the brake line. All the results did not have this tab and all brake lines that had to go over the chassis section just went straight, so I ended just making mine straight as well.
Also got all the body to pan rubbers in place and ready to go.
Started with the Laykold tape sound proofing, already making a massive difference to an empty shell. Also did the roof, which surprisingly looks the neatest even though I had to work upside down and used the 150mm wide tape.
Still need to do a few more spots.
I will admit the rest was not done very neatly, pretty hard to pull this stuff off once it has touched the surface. Working in shorts and getting your leg hair constantly stuck to this is also not very lekker. Lucky all this will be covered.
Then finally got the body back on the pan. body to pan holes line up nicely except for one hole not wanting to line up at the rear shock tower.
While the body was off the pan I took the opportunity to fill up and close any body seams and joins that were not properly filled just in case some water gets its way into there.
Flag: Netherlands
Post by retrovan » Thu Apr 25, 2019 1:54 pm
Looking good, keep going.
coming together nicely.
Rudi02
Been thanked: 25 times
Flag: South Africa
Post by Rudi02 » Thu Apr 25, 2019 2:00 pm
Well done thus far. Thanks for the update.
Rudi
My Rides http://www.aircooledvwsa.co.za/viewtopi ... =37&t=7837" onclick="window.open(this.href);return false;
http://www.aircooledvwsa.co.za/viewtopi ... 37&t=27064" onclick="window.open(this.href);return false;
Flag: South Africa
Post by Tony Z » Thu Apr 25, 2019 6:27 pm
looking amazing. All the hard work is going to pay off massively
Donovan D
Flag: South Africa
Post by Donovan D » Tue May 14, 2019 7:06 am
Thanks guys :hangloose:
Busy 'dry' fitting everything to double check that it lines up and fits before the interior can begin.
Installed a short shifter over the weekend but can not find 3rd and 4th gear.
Reverse, 1 and 2 is smooth and easy. Spent a good couple of hours adjusting the plate and trying to find 3rd and 4th without luck.
Removed the shifter and shift rod and I can only engage reverse with the hockey stick directly on the box which will eliminate fault at the coupler or rod.
The box has no oil in it and has not had oil in it for very a few years. I still need to get the axle booties on and also torque the drums on the axles. But thats not going to happen soon as I still have some work to do on the drums.
Any advice ? Do I need to pull the box and nosecone to check gears, or is there something Im missing ?
Has thanked: 17 times
Flag: South Africa
Post by Bugger » Tue May 14, 2019 7:18 am
Project comming on nice
Give me a call for advice on Box
I had it before myself on my Oval Bug I built many years ago had the box serviced and from the no oil in box and only oil from assembly also had a problem selecting 3&4 due to Surface rust
0826008663
Riaan.N
Been thanked: 20 times
Flag: South Africa
Post by Riaan.N » Wed May 15, 2019 7:41 pm
Nice shifter! Is it a Berg?
Flag: South Africa
Post by Bugger » Thu May 16, 2019 12:26 pm
Thanks for the Call
Glad you came right with te Spookpiss :D :D on the Selector fork it loosens up lots of things
Donovan D
Flag: South Africa
Post by Donovan D » Fri May 17, 2019 7:49 am
Thanks Pierre !
Managed to get all my gears.
Ive spent a good couple of days on 'quick' jobs lately, not much getting done.
Flag: Netherlands
Post by retrovan » Fri May 17, 2019 9:34 am
Thanks for the Call
Glad you came right with the Spookpiss :D :D on the Selector fork it loosens up lots of things
Come on Pierre, let us know what you recommended, it will be helpful to many with the same problem.
