My DIY farm buggy
Ricoffy
What model do you have?: 1600 off-road thing
Has thanked: 34 times
Re: My DIY farm buggy
Post by Ricoffy »
73type2 wrote: Wed Jul 17, 2019 1:23 pm
Ricoffy wrote: Wed Jul 17, 2019 12:41 pm For now I only have Saturdays to work on it - work and family consumes the rest of my time.
I know the feeling. Too many projects... I'm thinking about getting up earlier and do a small task every day before going to work in order to make some headway on my projects. Or maybe I'll start doing it when it gets a bit warmer and easier to get up.
The same thought crossed my mind a few times, but then I either:
1) Turn around and sleep further; or
2) Get up and work on the car, but then be frustrated for the rest of day because I can't finish the job.
Camshaft
Been thanked: 107 times
Post by Haans »
The best mountain crawler you can get and cheap to run!!
Weld up the spider gears in the diff,......effectively locking the diff!,.....then it will go anywhere!!
Nice job,.....don't forget four point seatbelts!,....with it's capabilities always being tested,.....things can go upside down before you can say. OH SHeeeet!!!
Ricoffy
Post by Ricoffy »
Haans wrote: Wed Jul 17, 2019 4:28 pm The best mountain crawler you can get and cheap to run!!
Your suggestion to weld up the spider gears intrigues me...
Do you have a picture of what it is supposed to look like?
Cheers
John Alves
Has thanked: 3 times
Been thanked: 48 times
Post by John Alves »
Ricoffy wrote: Thu Jul 18, 2019 8:48 am
Haans wrote: Wed Jul 17, 2019 4:28 pm Your suggestion to weld up the spider gears intrigues me...
You can also weld up a poor man's diff lock, have fun
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
Been thanked: 539 times
John Alves wrote: Thu Jul 18, 2019 12:03 pm
Individual back wheel braking.
This option makes the car more usable for both bushing and high speed.
Camshaft
Post by Haans »
Just make sure to pull up the correct wheels just before OOhhhh SHEEeet!!!
Camshaft
Post by Haans »
Seriously,......the suggestion to split the rear brake cables as per pic is the cheapest option. It will make it more drivable on and off road. To weld the gears, you need to dig into the gearbox,....
Your head MUST be in the game!!! with this setup,....braking the wrong wheel can be "problematic",.....could loose your lunch quickly!!
Ricoffy
Post by Ricoffy »
Front end and roof alu panels.
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Post by Terry Phillips »
I would change the roll bar corners to pipe bends as if you do roll it those 90 deg corners will dig in and send that buggy into a serious roll and I dont think those joints will stand up to a roll over. My 2 cents worth.
Ricoffy
Post by Ricoffy »
Terry Phillips wrote: Thu Jul 25, 2019 2:08 pm I would change the roll bar corners to pipe bends as if you do roll it those 90 deg corners will dig in and send that buggy into a serious roll and I dont think those joints will stand up to a roll over. My 2 cents worth.
I guess I shouldn't roll then :lol:
Seriously, the reason I went square is because of my limited skills and tools.
But thank you for pointing it out.
Camshaft
Post by Haans »
Boeta,.......see!!!! It is already anticipated that it WILL topple over some time or sooner. It is such a great toy!,...and a person tends to push the envelope further and further,.....trust me I have done it!!
Enjoy it!!!,....keep on the belts!!
Ricoffy
Post by Ricoffy »
Made some mud guards this weekend:
Been Following your posts on 4x4 Action Group aswell
nice to see the light at the end of the Tunnel
Ricoffy
Post by Ricoffy »
Bugger wrote: Mon Jul 29, 2019 8:25 am Been Following your posts on 4x4 Action Group aswell
Thanks Bugger.
Both my wife and my wallet are glad to see the project near its end :D
Terry Phillips
Zambia
Well done it looks great.
