![Very Happy :D](./images/smilies/icon_biggrin.gif)
who can tell me where is the best place to install a head temp sender and oil temp sender on 1600 beetle,
and what is to hot for the oil end to hot for the head??
![Question :?:](./images/smilies/icon_question.gif)
Yes oil that has been formulated for Diesel engines due to its high heat capacity.
Is oil actually moving there Herman?
Yes the oil can take a higher temp. as all modern cars run below 85 Deg C the oil has been formulated for this temp.
Ok Tony will do STAY AWAY tank you!!Tony Z wrote: ↑Fri Apr 17, 2020 4:27 pm Stay away from the delo. Their old formulation was good but was changed about 3 years ago.
We want 15w40 for the viscosity.
The rimula r4x has the perfect amount of zddp for our engines. No petrol oil today has enough zddp unless you can find SL grade and then it is still touch and go.
It’s the higher zddp that we need for our engines and this is only found in diesel oils
Thank you for the offerTony Z wrote: ↑Fri Apr 17, 2020 4:58 pm FWIW
viewtopic.php?f=4&t=38520&p=329815
I can import a few more later this year if you guys wish, should our borders open again
Tony is Diesel oil not too thick for the engine.
