Solar for Autovilla
Autovilla007
What model do you have?: 81 Autovilla
Re: Solar for Autovilla
Post by Autovilla007 »
Wow, Bugger thanks for that info. I would love to have a set up like that. I will continue my research on prices but already know that to duplicate your full set up would be out of my price range. Sean has some good points too, however a lot has been stripped from the Autovilla I'll be getting. It has a brand new, very tiny 220V only fridge. There is no oven or stove. No cushions, no table etc. at the rear. So quite a bit to spend. I'm also weighing up, if I get a gas stove/oven does it make more sense to get a 3 way fridge as well? So, within my budget, it may be turning toward a gas vs. full solar consideration. i.e. gas primarily with a small solar just to keep the battery charged for the 12V lighting, or a solar for fridge, lights etc. and only a small gas cooker. Bugger's solution is so ideal because I intend having the Autovilla set up for long term stay and wouldn't have to " break camp" to drive into the nearest town to get regassed as often. But, alas as said before, with the purchase of a snomaster, panels, batteries, chargers and inverters I'm trying to work out the short to long term benefits and costs. Thanks for everyone's continued input.
Again give us actually more info on your plans
Are you a retired individual going to travel and as mentioned stay at places for long intervals
And will you have Access to 220v?
Info 220v available
1x330W panel
10A solar charge controller
1x normal vehicle battery
As a start this will help you quite alot
Autovilla007
My apologies for seeming vague. As yet I cannot be certain of what I will have access to or not. My plan is to live in the Autovilla and travel into the Natal midlands and Drakensberg, hoping to find work where I can. Keeping costs low will be essential, so staying in caravan/camp sites will have to be kept to a minimum. I would expect that where I can find work I should be able to get 220V access aswell. But, for the times I don't, I would like to be as equiped as my budget allows.
I appreciate everyone's inputs (and humour) here. Everyone has some advice/opinion/experience that I can draw from.
Glad we could help
Yip equipment is always budget related
