Anyway, on with the rebuild.
Today I managed to clean out the driver side heater cable tube. What a hassle. First managed to pull out the inner then unraveled the outer which luckily came out except for a bit of plastic sleeving. This I managed to get out this morning.
The passenger side is a completely different story. Could not move the cable at all and then resorted to cutting out the tube in pieces. Evntually found a section of about 10 cm was solid. So now I am either looking for a replacement tube used or new or I will attempt to clean and weld back together.
Also started cleaning off the old rubberizing, another real pain in the....
When tired of the one job I alternate to the next which is removing the battery tray on the left side so I can panel beat the corner.
I think I might not even use my new panels I imported. These will become obsolete and sold once I am done.
