Hi All,
I recently reconditioned my type 4 engine for my 1973 Westfalia and the previous owner moved from a dual carb Solex setup to a single carb setup using a Golf MK1 1800 carb.
The base unit were the carb is connecting to seems to not allow the air / fuel mixture to flow freely as the is no splitting mechanism to flow the fuel equally.
It seems to be a botch job as it literately a flat base square metal box.
Issue I am experiencing now is a heavy flat spot when trying to get refs.
It eventual comes right but not good for stop start traffic.
Anyone perhaps selling a base unit that is fit for purpose?
feedback will be appreciated.
Regards
Type 4 2 Liter Single Carb Manifold.
- sean
- Has thanked: 63 times
- Been thanked: 227 times
Re: Type 4 2 Liter Single Carb Manifold.
It will never work correctly.
Throw it away and fit the standard Solex dual carburettors. Your problem will then be solved.
If you don't want to consider used or original, then you can use dual Weber ICT's or IDF's.
- Has thanked: 18 times
- Been thanked: 58 times
Yip that manifold does not sound good
Vdubtech might have the Correct single Carb convesion kit available or we can build you a decent std duel Carb Setup
info@vdubtech.co.za
0118222799
info@vdubtech.co.za
0118222799
WestyMS
- What model do you have?: 1973 Westfalia
Thanks all for the reply. I believe that Volkspares also sells type 4 parts so will call around for best price.
64 Notchback
- Has thanked: 78 times
- Been thanked: 37 times
Not sure if this will help but I have 2 CU 2l motors ( well actually 1 and a half) with carbs and manifolds.
These need to be repaired.
Can send whatsapp pics if anyone is interested.
- Eugene
- Has thanked: 59 times
- Been thanked: 65 times
Why don't you show us pictures of your ride in the mean time
WestyMS
Flower Power.
Itching for a proper road trip
- freddiebooysen
- Been thanked: 47 times
Looking really good
And that road trip better happen and we want a nic trip report as well with loads of pics
