Front window inner scrapers
- Edmond
- Has thanked: 22 times
- Been thanked: 40 times
Found some inner front window scrapers at Pro Auto rubber but they come in a 4 clip and 7 clip version, anyone know what version would fit a 1973 beetle TIA
- Been thanked: 98 times
Re: Front window inner scrapers
7 clip is for 66-68, 4 clip 69-79
- Edmond
- Edmond
Strangely enough my 73 Baja actually takes the 7 clip inner window scrapers, I know have a set of 7 clip and a set of 4 clip scrapers, going to try fit the 4 clip ones on the outside scraper aluminum trim, the ones on there are shot
- Herbie
- Oil Cooler
- What model do you have?: 1978 Beetle SP 1600
- Has thanked: 9 times
- Been thanked: 35 times
Did you manage to be successful?
Blood Type: VW+
1978 Beetle SP 1600
1963 Beetle
1978 Beetle SP 1600
1963 Beetle
- Edmond
I haven't got around to it yet but did manage to strip the outer scraper alu frame successfully out the doors so will see this weekend if I can make the inner scrapers work with the outer scraper moulding, just need very small tubular rivets, I was thinking of using eyelets to hold the scrapper moulding and metal stiffener to the outer scraper alu frame. I have stripped the doors fully, removed all the vrot felt channels, veny windows, scrapers etc
