Buggy engine cutting out
Don't want to register but want to ask a question or post something aircooled for sale? Post here.
Frustrated
Post by Frustrated »
Help Please. My buggy has suddenly developed an issue of randomly cutting out while driving and then will not start. Leave it for a day or two it then starts. Have replace coil,ignition,points and condenser . Any suggestions what could be the cause.
Re: Buggy engine cutting out
did you recently tighten the nuts by the fuel pump to stop a leak? If you did, loosen them up a touch and live with the leak
Guest
Post by Guest »
No have not touched the pump. Have notice fuel filter has quite a bit of dirt in it.Going to preplace tomorrow, It seems to only cut out going uphill.
Could be that you have dirt in your tank which restricts fuel coming out, so when the fuel in the carb and pipe is gone, the car stops.
The dirty fuel filter should give you a clue that you have dirt in your tank doing this.
Now the next is something you should do after you have drained most, NO ALL, the fuel and have it standing where fuel spillage will not matter, place a tray under tank, remove the tank outlet, it should have a filter over it and let the little bit of fuel in the tank wash the bottom of the tank clean out.
Clean the tank outlet filter, blow out the pipes and refit.
Now remove your in-line filter and remove pipe from carb, blow out any dirty fuel and muck out of the pipe before replacing the in-line filter and re-fit the pipe.
Fill tank and try again.
If not right, you could have dirt in the carb, but I do not think so.
Good Luck
Cyndi Kritzinger
Facebook: yes
Been thanked: 64 times
Post by Cyndi Kritzinger »
ANOTHER POSSIBILITY IS THAT YOUR PIN OPERATING THE FUEL PUMP IS GETTING STUCK IN THE FUEL FLANGE WHICH EXPANDS SLIGHTLY WHEN HOT.
NOT YOU EVERY DAY OCCURANCE BUT IT IS A POSSIBILITY.
John Alves
Has thanked: 3 times
Been thanked: 48 times
Post by John Alves »
Is it a sudden shut down (electrical) or a fade (fuel starvation or flooding ) sounds like you float level check valve is not working filling up the float chamber and flooding the motor, especially going uphill, after a day or so and a little evaporation the float level is back to normal and you can start the car.
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
John Alves
Tony Z wrote: Tue Oct 27, 2020 2:03 pm did you recently tighten the nuts by the fuel pump to stop a leak? If you did, loosen them up a touch and live with the leak
live with a fuel leak???
1968 1500 SP Beetle
german
What model do you have?: none yet
Has thanked: 11 times
Been thanked: 7 times
Post by german »
Oil leak
John Alves
me dumb, of course its an oil leak :(
1968 1500 SP Beetle
