Limited stock, more arriving regularly.
Contact me (Tony) on 0833418937 (whatsapp friendly) or pm me on this forum
Wir sprechen Deutsch
Fan dress-up kit/tinware
Oil filler breather box
36hp style fanshrods, with external "doghouse" style cooler (later 1600 engines)
Full flow oil pump covers
Wide Glide oil sumps - 1.5L and 2L extra oil capacity - thin and wide, minimal change in ground clearance
OEM Distributor O-rings
New rocker arm nuts / valve adjuster nuts - Heavy Duty and thin (no more rounded off nuts and slipping spanners
New OEM oil filler cap
HD, long life steering coupler
Porsche Style Valve adjuster
Rocker spacer, shims and adjusters
New Stock style gland nuts (flywheel bolt), new stock washers (Wavy / Belleville) and HD Racing Galnd nut with oversized washer
Oil filler necks - stylish and easier to use than stock.
Oil change kit - includes gaskets, new sump plate with drain, new drain plug and new mesh filter
Cam gears for performance/racing cams
Early bug horn covers
New oil coolers
Barrel shims for stock size barrels and oversized (90.5mm, 92mm and 94mm piston sizes)
Titanium valve retainers, Cro-moly valve retainers, HD lash caps (wear caps - protects valve head from wear) and rocker shim packs for solid rocker shafts
New CB performance 044 heads, 94 bore, 42mm inlet valves, 37.5mm exhaust valves, dual HD valve springs, Cro-moly retainers. Unported
H-Beam racing con rods, various lengths, VW and Chevy journals
Clevite Rod bearings and Silverline Dual thrust cam bearings
Type3 style lower cylinder tin
Pushrod tubes - 40hp, stock 1600, Windage, racing, stainless steel, and Silicone Pushrod tube seals
Engle W100, W110 and W120 camshafts and Engle lifters/followers
Rhino engine/transmission mounts
Oil pumps with filter mounts for early and late cams (stock and performance 1600 style cams)
Oil filter mount for remote mounting of oil filter on full flow cases
Wafer adapter - mounts between oil filter and its mount to allow oil to be sent to external cooler
Quick shift kit - made from metal, not plastic like other brands
Billit oil dipstick
Serpentine belt system
Sand seal pulley (left) and billit aluminium pulley (stock style with degree markings) on right
Cro-moly head stud kits with new (thick) washers and HD nuts - 8mm
