the high rpm "break in" is for a new cam
rev it once or twice to make sure it gets a little oil and then drive
Beetle 1300 Single Port Heads Headache
Re: Beetle 1300 Single Port Heads Headache
- Has thanked: 141 times
- Been thanked: 100 times
If you don’t have the original Beetle spark plug wires, or are cheap like me, you can use Bougi wires and add a little rubber disk to seal the hole:
Another headache for me is to find a properly fitting oil breather hose. I wanted cloth covered 1/2inch hose, but couldn’t find it, so I resorted to using general purpose hose. The problem is that it’s too stiff and puts too much tension on the airfilter fitting. A plastic irrigation elbow fitting sorted it out:
