Hi guys
This discussion came up oberbthe weekend .
Can a 1500 single port be converted to Twin without any Issues .
I said yes because i converted my sister's 1300 67 to twin port and slaped a set of 36 Weber IDF'S on it and topped it off with a 009 Dizzy.
She ran for years like that no issues .
What is your consensus around this .
Can a 1500 be converted to Twin port
Re: Can a 1500 be converted to Twin port
In theory, its just tinware, different head studs and the heads that are different on the long block.
- Has thanked: 45 times
- Been thanked: 208 times
Ideally one could also fit the "doghouse" cooling shroud, wider fan, and oil cooler from a dual port.
