Engine Tin - coating advice
No More Landy
What model do you have?: Beetle 1971
Has thanked: 23 times
Been thanked: 6 times
Germany
Post by No More Landy »
Hi Guys
Anyone that can recommend a process to coat engine air cooling ducts/bits and pieces including fan housing ?
I did mine about 6 years ago but all that coating is gone. (Mostly)
At the time I had them sandblasted but can't remember the type of paint coating they put on after.
Thanks in advance.
1971 Beetle
2021 Polo tsi
2006 Defender Kalahari
Re: Engine Tin - coating advice
I've used powder coating quite a few times, always with good results
Other than that, just applying Hammerite also works
Riaan.N
Oil Seal
Has thanked: 3 times
Been thanked: 38 times
Post by Riaan.N »
+1 for powder coating.
Rust-Oleum “enamel” spray cans are my go to paint for small parts. Alternatively automotive 2K, but here the primer becomes becomes important.
Surface preparation is also important.
No More Landy
Germany
Ended up using Quality Coatings in Paarden Eiland as per the owner of Flat Four's suggestion for powder coating.
Brilliant job and cheap as chips.
1971 Beetle
2021 Polo tsi
73type2
Has thanked: 141 times
Been thanked: 100 times
France
Post by 73type2 »
Good to know. Thanks for the tip.
