when you get the next set of doors. Look at the bottom of them, they have small drain holes.... these are often blocked so the water stays in the dorrs, leading to the rust problem you have......
each and every car i get i check that all drain holes are properly open, doesnot matter on what make and model it is. and i also 1 a year take the door panels of and wash the inner doors properly out with water and soap
PS. must say the 2 doors that i have is on the inside in a good condition, or at least the one is , because it is open , i will open the other one to have a look on its condition on the inside
Rust, rust, glorious rust! Theres nothing quite like it for eating my bug!!!
"My other ride is your SeatCover! & She loves it!" Sometimes you'r the statue, sometimes your the pigeon. "Only the dead go free..." Roger Waters. "You do not understand the power of the DarkSide" Darth Vader.
"Understeer is when you hit the wall with the front of the car, and oversteer, the rear. Hp is how fast you hit the wall, and Torque is how far you take the wall with you."
