Late night Friends
Come talk £%$ with us.
Seeing that I'm on my own,I kept myself busy on the site. :twisted:
IM just popping in and out looking for new posts.
Well,I posted a few.hehe
What in your opinion is the correct way to bleed brakes. I start at the cylinder furthest from the master and work around. this is done by opening each bleeder.and using a piece if pipe into a small bottle with some brake fluid in and pumping the pedal until all the air is out of the system. I think I have now cut my problems down to one wheel. How or what is the easiest way to see if you have a hole in the pipe work bearing in mind I dont see any leaking brake fluid. And how do you know if your master cylinder is faulty. I dont believe mine is as I said before 3 wheels seem to be OK.
Have you opened up said wheel yet?May be you have a slow leak.What happens is that the brakes will fade overnight while the car is standing,so you wont see a leak as such.
The brakecyl.could have pit marks in it ,then it slowly loses pressure.
vader
Post by vader »
Is that what is happening to the wheel? Loosing pressure? whats it doing?
OOPS!! I forgot to mention I now have disc's all round, so I dont have the standard wheel cylinder.
vader
Post by vader »
well on the other hand Darren.....
Do you have disc vibration when you drive,iow,does the brake pads rattle?
Been thanked: 489 times
if the calipers are old, you may need to have the faulty one reconditioned...
What exactly is your problem with the brakes?
How is the cold tonight,Tony?
still there, but getting better. At least I was able to study today, yday and wednesday I couldnt even read...
Thanks for asking
Sh!t time to have a cold.When's the exams over?
4king hell my daughters new rabbit decided to go for a swim at this time of the morning. back to the subject. unknowns to me i had a buggered rear wheel bearing with oil running onto the rear disc. The brake pedal worked fine and then started a strange behavior as follows. I would apply brakes evenly but the braking would actually fade and then return and without adjusting my foot pressure on the pedal the grab and fade would repeat itself. I then decided to put discs all round and since that day I have not been able to get the air out of the system. As I said it now seems that there is a problem with the right front which is nearest the master cylinder. Once all the air is out and you get no bubbles in your bleeder bottle the pedal is quite tight. But give it a few minutes rest and the pedal goes back to the floor. You then need to build up pressure by pumping the brake pedal once or twice. Hopr this explains my problem.
It sounds like the pod seal is defective.I would ,for ,safety sake,open the caliper,and check if the seal is still ok.Als check the brake pad thickness.If you are running a golf setup,it might be that the pads may be too thick.Remember,there are two thicknesses on those pads.
