Advice GIVEN for a change
How to prevent your brass fuel pipe from pulling out of the carb, and set your VW alight:
If you have a carb, safety wiring the pressed in brass line going in there.
SUZIE
Re: Advice GIVEN for a change
Post by SUZIE »
Thanks Pine, i will do it with mine
Surge
Post by Surge »
Yeah, standard practice on the critical lines in my "retired" bug (oil + fuel lines).
Nothing like decent hydraulic screw fittings though.
I once had the barbed fuel pipe in the carb come out of the carb (intact with the fuel line still clamped to it) while I was driving and I drove it till it started chugging (one float chamber full). Fuel all over the engine and it must have pumped a few liters because the fuel gauge dropped drastically in the process. Good thing there were no sparks ...
IMPI
What model do you have?: sp2
Been thanked: 78 times
Post by IMPI »
if the pipe is loose just tin the end with solder lightly and hammer it in This fix works very well and does not come loose
ZeroAxe
Drive Train
Post by ZeroAxe »
IMPI, I would kiss you if you werent a geezer! I *need* to do this to one of my Fasty's carbs.... :hangloose:
VW Enthusiast
