Reminds me of '80s/early '90s BMX chainrings.
N.
Calooker wrote:The block has now been cleared to take the crank and it now turns, rods 1& 2 rod area in block also cleared and fitted to crank are turning need to do rods 3& 4 in block, as well as trimming the back of the pistons and thinning the skirts as they are touching the counter weights.
The centre main bearing housing needed about 1.5mm of material removed to clear the cheeks of the crank, plenty trial fitting and grinding. Will have the short block finished by the weekend.
