1600TP, when I got this motor it was running fine, a *friend* (uhuh)needed some cash so I let him do an oil seal kit replacement on the motor. After 3 weeks I pick up the motor cause he's still not done and found this.
He'd left the carb of the baseplate and water went down the intake, passed the pistons and ended up in the sump. I stripped the motor down to pistons and rings, luckily there was no damage. Here's the deal, the bus overheats after about 20 minutes of driving.
It has a 009 on it, and has been like that even when the motor was owned by the previous owner, The motor is 100% stock.
I've replaced the fuel pump, timing is spot on, but this sucker overheats. All engine tin is in place, engine compartment seal is there, but this problem persists..I'm pulling the motor tommorrow and I want to strip it down again. Any help?
What's the chance some sludge has ended up in the oil cooler and it's blocked? Wouldn't it blow the cooler seals though?
