I have a question which I am sure has been asked many times, but can't find too much about it on ACVWSA. My concern is that my standard 1600DP AC engine has a knock at idle
, but it gets softer, and almost disappears as the engine revs increase
. While I am standing at a intersection waiting for the green light, I can hear the knock inside the car, but when I drive off, if disappears. I do not have to rev the engine very high to get rid of the knock... so my first question is: I know this is a serious problem, because it is related to the engine bearings that are worn, but if the knock is only audible at idle, can I still drive the car like that for a while? Is the problem extremely serious (does it need immediate attention)? If I drive the car with the knock until the end of the year, will it badly damage any parts, making the engine reconditioning more expensive?
I don't want to ruin a good engine. It does not smoke and has good power.
Secondly, if I eventually have some time and cash to spend on the car (end of the year), what will I need to do a complete engine rebuild? This will be the rebuild to get rid of the knock as well. I have a few basic tools like sockets, spanners, pliers, including a socket + cheater bar for the flywheel nut. So what tools will I need? And secondly, in terms of the crankshaft, Pistons, con rods, Camshaft, Heads, Valves, Rings, Pistons, etc... what should be replaced or machined by a shop?
I will also buy or build me an engine stand to put the engine on as I work on it, and get me a Haynes Manual with the Engine Rebuild section...
How much does a rebuild of a standard engine usually cost (more or less)?
I really love my bug
