DC PROGRESS - BUSY WITH INTERIOR
- SUZIE
Re: dc progress
the problem with the wireing is not at the moter side, it is all the wireing going to the so called fusebox and what is left of it under the dash, but i am slowly getting to it, all the wireing from the fusebox to the tail lights are sorted out now, so now i am busy with the wireing for the headlamps to the fusebox
- Watercool
- Been thanked: 6 times
Re: dc progress
Man, I would love to get my hands on a DC, but as they where never officialy imported into the US they are like hens teeth, and if you find one it is one of two ways - scrap or super expencive. But my Vanagon keeps me busy enough, I thought about the 4 individual seats but I will go bench (dont know out of what yet), and Porsche buckets up front. The V8 install eats up some space so I decided to loose the back seat, but gray or black leather will be color of choise. Got the plasma tv for the back seat and the sound system - about 1000 watt thru 4 10inch bass woofers and 14 other spreakers. Woofers will be mounted under bench seat for the thump feel. But I will post pics as soon as I have them ready.
- SUZIE
Re: dc progress
Some progress with the wireing has been done this week, most of the stuff works and it is only a few small things that still needs to be rewired and connected.
1 ste pic = roof light that i fitted, need a few more of this one for the DC and my golf
2 nd pic = partial of dash wit chico steering wheel
3 de pic = the new engine pully to run aircon and powersteering on the V6 engine
- SUZIE
Re: dc progress
1 ste pic = busy with main dash
2 nd pic = plumbing for oil gauges
3 de pic = wireing that has been cut out
Re: dc progress
Looking good SUZIE.
I was also supposed to use that 180 KM/H Autogauge speedo for the fasty, but then got a late Bay 140 KM/H speedo from Pine
- SUZIE
Re: dc progress
Have done so far a lot of the wireing, whats left to do on the wireing is radiater fan, dizzy and sigeret lighter(no i do not smoke)
the starter turns the engine very nice and fast over yesterday in a test swing. also used the ryobi drill to test the oil presure light and gauge, works well, the presure come qiukly up and then the drill doesnot want to turn, well it is rather a small drill i used on the oil pump shaft, fited the dizzy nou it is to wire it.
small things but yet some of them are expensive that still needs to be done on the DC
carpets + re upholstery (still rethinking of putting 4 buckets seats in or 2 buckets front and one bensch seat at the back)
tyres and mags
new shocks
exaust
gear selector shaft
sound system (think i will take my Cti's sound out and install it in the DC)
power inverter for the playstation
install playstation
freezed box
aircon
powersteering
wheel alingment
safetybelt adjusters
just a few things i can think of
tyres and mags
new shocks
exaust
gear selector shaft
install playstation
freezed box
aircon
powersteering
wheel alingment
- beetlefanatic
- Has thanked: 8 times
- Been thanked: 12 times
Re: dc progress
Looking good Suzie. I would personally go with the full rear bench. I had a 2 seater from a caravelle before but it was a bit cramped with some wasted space. I installed a full bench from a Caravelle and adjusted the seatback a bit more upright. This means the seat can move a bit more back and give more legroom. It's great for going to the Kruger and also for travelling. Mom can sit at the back with my daughter and watch DVDs or play games on the removable screens. Next time I'll build my own rear bench and customize it with place for a fridge.
- SUZIE
Re: dc progress
I wanted to fit the 2 seat at teh back with a fridge inbetween to have cold beers and drinks for the passies, but now that the laaitjie is here and the wife is nagging for a bench seat.
did you use the rear one from a caravelle or the centre one?
- beetlefanatic
Re: dc progress
I think it it's the center one. It has the one flip down seat. I am planning to mount the jack etc behind it in that cavity. Makes it easy to get to. Behind the long piece the sounds system's amp and maybe a flat sub.
- SUZIE
Re: dc progress
i started the Dc engine after 5 years, althou the carb currently on is not its origenal one it started and reved nice, but did not want to idle, one of my old have nothing on the cards now, but have a red beach buggy in sight that I want
- SUZIE
Re: dc progress
So i fitted this time a gud filter (will take pictures to show what is the difference between GUD and Fram and why you should not use fram on your engine then. also refitted my new carburator and it works like a charm no hufing and no oil filter poping, filled her last night with water, just a mere 16Liters, dem that is alot, but notice a smaal leak on the dariator, bleeded the clutch and bleeded the brakes but not so happy with the brakes and the hand brake s performance, but every thing is new and i think they need a little run in. started with the gearlinkage, oh my that is not so easy one so i will have a try agian maybe tonight.
- SUZIE
Re: dc progress
i fitted New Safarie gabriel shocks yesterday , also did fit the lisece disc and the new numberplates, busy now with the door seal rubbers.
to do list for the weekend
alternater light ( still a problem)
rewire the radiator fan
bleed the brakes
adjust handbrake
adjust gear linkage shaft
fit mags to the DC 17" but will see if i get to this one as i do not get a big assortment of mags in Newcastle
then take it for a test drive
bleed the brakes
adjust handbrake
- SUZIE
Re: dc progress
update for the past weekend .
finished the wireing problems, alternator is charging now, had big problems with the bleeding of the brakes but got that sorted out, still has to do the handbrake adjusting. tooked it for a spin around the block, still battles with the gears, have now reverse, 1ste and 3de gear, no 2nd and 4th, will try tomorow morning to readjust the gear shaft. got my new set of 17" shoes, will fit them tomorow and hopefully if the gears is right i will take it qiuckly for wheel alignment, the exaust if stuffed, will do that later this week.
- SUZIE
Re: dc progress + MORE PICTURES
SUZIE wrote:fitted the engine and gearbox last week, wireing still a big problem to sort out, but i will take my time on it
- SUZIE
Re: dc progress
AD MAGS
