Cant get my bug to start again
- hitlers revenge
- Been thanked: 36 times
- fig
- Bus Driver
- Has thanked: 287 times
- Been thanked: 322 times
I agree with Calooker. Don't mess with the carb until you are certain you have eliminated all other possibilities.
Most similar problems relate in some way to the ignition: either tuning or faulty condensor or coil in most cases.
Okay so after doing the everything I said I would she is running but there is a bit of delay when swinging before she ignites. Idling is soft 1st then goes loud and runs perfectly afterwards. But the other thing is there is a bit of a hissing sound coming from somewhere, so I gather she must have a vacum leak somewhere.
Could the delay in ignition be incorrect mixture of air & fuel?
- Thumper
- Has thanked: 6 times
- Been thanked: 13 times
Air sucking in, ANYWHERE, except the carb is not good news.
Find those leaks, and the engine will run smooth.
- Been thanked: 98 times
Check the points gap it must be 0,4mm, should start nicely after that.
- fig
- Bus Driver
I thought points gap was supposed to be 0,4mm???calooker wrote:Check the points gap it must be 1mm, should start nicely after that.
The points gap determines dwell angle, and is just a rough measure. To be sure, one needs to use a dwell meter.
