61 Westy
Re: 61 Westy
Good going.Now you can take it for a spin.
- lowlight
- Been thanked: 14 times
Re: 61 Westy
This is taking too long got a quote to do the paint work. Started to strip inside to get the welding done.
- lowlight
Re: 61 Westy
Need some ply wood for the farside
After most of the inside is stripped out for welding.
Need new wood for the floor aswell
- lowlight
Re: 61 Westy
Stripped the lights and some other small things.
Panel beater called today would like to have the bus tomorrow, as he got some space to work on it.
so it is ready to go. will strip the windows next week at the shop.
- Has thanked: 36 times
- Been thanked: 50 times
- lowlight
Re: 61 Westy
The bus is delivered to the panel shop. Hold thumbs it will look smart.
ajvw
- What model do you have?: 70 kombi
Re: 61 Westy
lowlight, are you removing the original interior and replacing with another...if so please keep it all every nut and bolt as i`m sure someone on here will one day want an original interior. They are like rockin horse doo
waassuupp
- lowlight
Re: 61 Westy
NO, they will go back inside after the welding and spray painting.
Re: 61 Westy
Hey AJVWajvw wrote:lowlight, are you removing the original interior and replacing with another...if so please keep it all every nut and bolt as i`m sure someone on here will one day want an original interior. They are like rockin horse doo
How about an intro in the relevant thread
- lowlight
Re: 61 Westy
Removed the front windows and doorpanels. Struggle with the side window skrews, will try tomorrow again.
- lowlight
Re: 61 Westy
This is takting much longer than I thought.
I took out the windows on the front door.Q20, Q20, Mans best friend, back window aswell. 6 side windows Im struggle with, will drill them out seems to be the answer
http://i252.photobucket.com/albums/hh19 ... IM0704.jpg
- lowlight
Re: 61 Westy
Also shrink the fenders.
http://i252.photobucket.com/albums/hh19 ... IM0701.jpg
- hitlers revenge
- Been thanked: 36 times
