black is beutifull
beesbal
Oil Seal
black is beutifull
Post by beesbal »
hoping to finish this soon :D
SUZIE
Re: black is beutifull
Post by SUZIE »
Nice, what color are you going for the roof
beesbal
Oil Seal
Post by beesbal »
SUZIE wrote:Nice, what color are you going for the roof
all black,thats ms ms primer on the roof,still a lot of flatting before the final cotes,want to get the best finish possible
SUZIE
Post by SUZIE »
why do you paint your car in satges if i might ask? not very good idea for color and overspray to do in stages
beesbal
Oil Seal
Post by beesbal »
luckly on these cars most of the part are easy removable,fenders etc,makes it easy er,I think-could be wrong
beesbal
Oil Seal
Post by beesbal »
For the final cote I will start with the roof and work my way down from there,black isnt easy colour to work with
SUZIE
Post by SUZIE »
any dark color is dem dificult, so you going to flat the already black painted areas again?
SUZIE
Post by SUZIE »
beesbal wrote:luckly on these cars most of the part are easy removable,fenders etc,makes it easy er,I think-could be wrong
for a solid colr then yes it is easy but if you going for metalic or pearl, rather paint all while it is on teh car and with once everything and make sure all pannels have the same amount of coats on
beesbal
Oil Seal
Post by beesbal »
Thanks for the tip,you know how it is with these things allways run marks or something,the allready black areas will still get at least two more cotes(spray flat,spray flat and so on)
SUZIE
Post by SUZIE »
Then it sounds realy good, what block do you use for the flating in between the sprays?
bugspray
Floorpan
Has thanked: 24 times
Been thanked: 16 times
Post by bugspray »
Schweet ride. I was going to go black fenderz n doors and gun metal silver trunk,roof and lid. But i settled on the chev lumina purple, but with a personal twist. (1 litre pearlescent white/blue) when your done, and ready for the final coat, you rather spray everything together at the same time. What finish you going for? Pearl,gloss?? What paint you using?
beesbal
Oil Seal
Post by beesbal »
bugspray wrote:Schweet ride. I was going to go black fenderz n doors and gun metal silver trunk,roof and lid. But i settled on the chev lumina purple, but with a personal twist. (1 litre pearlescent white/blue) when your done, and ready for the final coat, you rather spray everything together at the same time. What finish you going for? Pearl,gloss?? What paint you using?
2k paint.high gloss thinners.2k thinners dont give high gloss finish,very thin final cote,more thinners that paint
beesbal
Oil Seal
Post by beesbal »
SUZIE wrote:Then it sounds realy good, what block do you use for the flating in between the sprays?
I work my way to a finer grade in between cotes,before the final cote 1000g should do the trick
gazzapen
Post by gazzapen »
Watch out useing, high gloss thinners on 2K.
2K thinners composition is made especially for 2K. High gloss might give you a better finish initailly but in the long run it becomes faded and often develops cracks easier. The same for Base coat thinners. Thinners is designed to dry at a specific rate so as to ensure that the paint dries at the correct rate. If the rate at which the thinners dries is incorrect the paint is streched or shrinks resulting in a poor finish. Often only visible after some time.
Sprayed our previous Microbus thrice before we realised the spray painter was usein the wrong thinners.Worse, everytime we only found out a few months after it had been sprayed.
SUZIE
Post by SUZIE »
gazzapen wrote:Watch out useing, high gloss thinners on 2K.
Thanks Gazzapen, this solves my mystery that i had on my isuzu paint started to crack, looked like this old antiqe vases.
