clutch cable
fsf
What model do you have?: 1967
clutch cable
Post by fsf »
hi guyz i have a big big problem i want to fit aclutch cable & its been 2hours i cant get it to hook there in front & my fingers hurt like hell i dont know what to do anymore plz guyz i need help :? :? :zhelp:
IF YOUR NOT WITH US THEN U ARE NOT A MEMBER
Re: clutch cable
YOu need some slack there in the front and its helpful if you can get someone to assist you with holding the pedal in position as required. you need to bend the "loop" over to get it over the hook and then carefully feed the slack backwards. Its not easily but its doable. I had my arm stuck in that hatch quite a few times. Good luck
fsf
Re: clutch cable
Post by fsf »
thanks im going to try that first thing in the morning coz now i need to put my fingers in cold water to cool down. THANKS YOU eben
IMPI
What model do you have?: sp2
Been thanked: 78 times
Re: clutch cable
Post by IMPI »
You need to loosen the whole assembly so that the pedal can lie flat back wards then it is quite easy to hook up
