HELP the Oil Lights On!!!!
- What model do you have?: '73 Bug + 67 Bug
Ok just started driving my big (73 model) after about 2 months rebuild, before then she ran sweetly, have done nothing to the engine at all, and today started her up and went for a drive, and the oil light stays on, First checked oil levels, fine , ans she picks up revs it goes out, but once in fourth gear comes back on whilst cruisin.....hmmmmm, also seems to be runnin rich and a bit hot.....WTF do I do?????? HELP is needed!!!!!
- What model do you have?: 1600TP Willys
Re: HELP the Oil Lights On!!!!
Don't drive it!! Try replacing the oil pressure sender unit - the light should go out when you start her up.
Rust NEVER sleeps
I will second that , you never know whats gone Oli pump Blocked oil cooler list goes on.....................BAB
- Been thanked: 98 times
The Idiot light comming on during driving is bad news, you are looking at a rebuild soon.
- eben
- Site Admin
- Been thanked: 54 times
what oil are you running?
- vader
- Has thanked: 9 times
I'd say put some Duralube or prolong in and then just put a sticker over the oil light and carry on driving...... But then again I use the Force(less) in my DarkSide.......
Disclaimer...... Under no circumstances should you ever take any engine advice from anyone who has had 8 engine rebuilds in the last 18mnth or replaced their engines 9 times in 18yrs..... hahahahaha
Thanx for the Help guys, specially vader, My force failed too , but you will get over it. Anyways as it turns out, the problem was the Oil pressure switch, that has now been replaced , the carb set and the timing adjusted, so all I can say now is
YYYEEEEEEEEEEEEEHHHHHHHAAAAAAAAAAAAAAAAAAAA, ruby rides again....
