Sub Assembly
Eye Candy
What model do you have?: 1969
Sub Assembly
Post by Eye Candy »
Hi,
My beetle is a 1975 VW Beetle 1500 TP
Please help, my beetle is making all bearing like noise. I start up and all sounds ok, drive for about 10minutes then that noise starts and in the next 10minutes the car swithes off and wont start till i let her rest for 30minutes.
If it is the worst case, can i put a 1600 sub assembly or engine intomy bug, and what changes are to be made if any...
Urgent help thanks
vader
Re: Sub Assembly
Post by vader »
You can do a straight swop with on changes.....
Re: Sub Assembly
Check if there isnt something stuck in the fan. Also check that the fan isnt sucking the firewall into the fan inlet.
SOunds like you are overheating
