All you ever wanted to know about the SP Beetle
IMPI
What model do you have?: sp2
Been thanked: 78 times
Re: All you ever wanted to know about the SP Beetle
Post by IMPI »
Yes
There were lots of aftermarket 14in Rostyles, though, so not too hard to find.
I have 14 inch Rostyles on my ride, was wondering if they are original Vw or aftermarket...
Has thanked: 45 times
Been thanked: 208 times
Post by Dawie »
Rostyles 14x 5.5 were available from the VW spares department. Bought a set for my first car, (beetle)from them, they were R18. each,and there were no vat in those days,(late seventies).
There was a rumour that SP beetles had a taller 4th gear to compensate for the low profile 14inch tyres.
This proved to be false, as you can see in the specs on the previous page. Went to several scrapyards as i was desperately looking for one. Found several SP's with the gearbox still in the car. Turned the input shafts and counted the turns of the brake drums.
All had the same 0.93 fourth as with the normal late 1600 AS code gearbox.
Maybe a handful of the first SP's had a different ratio?
Would be interesting to see the 1977 Car road test that Blitzkrieg promised.
Yes I will post it in the next day or so...
A lot of people reckon that it was the best Beetle ever from an SA perspective. The only part that I don't like on the SP (Or any late '70's Beetle for that matter) are the rear light spacers....
IMPI
Post by IMPI »
Further useless info
Solex carbs
155 main jets
air jets 110
idle jets 52.5
power jet in carb body fixed 100
beesbal
Oil Seal
Post by beesbal »
The easy st way to spot the difference between a Sp and normal bug is to look at the spare wheel compartment.
The spare in the sp will lay flat and the spare in the standard stands up
Has thanked: 235 times
No, the spare wheel in an SP looks exactly the same as any other Beetle. Only the 1302 and 1303 has a spare wheel well that lies flat.
beesbal
Oil Seal
Post by beesbal »
Pine wrote:No, the spare wheel in an SP looks exactly the same as any other Beetle. Only the 1302 and 1303 has a spare wheel well that lies flat.
See what happens if you believe all the KAK that people talk,Thanks Pine wasnt aware of that.
There is a lot of misinformation about the SP - it was basically a standard SA Beetle with a few accessories, as mentioned by IMPI
beesbal
Oil Seal
Post by beesbal »
like the extra clocks and so on
And some stripes over the roof and door. And so on.. :wink:
beesbal
Oil Seal
Post by beesbal »
And some dual carbs and so on :D
And some coloured square weave pattern on the seats. And so on..
As promised, here is the 1977 road test by CAR. They reckoned that they would rather take the 1600S :roll:
Image Image
These are very interesting cars, would prefer this over an Oval any day :P :twisted: :finger4u:
