Quite some time ago, Armand (IMPI) responded to a query I hard regarding the bearing numbers for bus rear wheel bearings...
I unfortunately had this info stored on my USB drive which got scaled
Do any of you happen to have all the bearing numbers for the rear, and how many of each I need to replace both sides?
Thanks!
...I'll be buying from Bearing Man, unless you can recommend somewhere else too.
Cheers, N.
