suicyde engine
where do you see a notch? No, sorry, no notches there
Early 3 bolt cam config. ?
Lube on the lobes ?
No none of those either... I thought you may have got it on your first guess....
I'll give you guys a few more days
Has thanked: 19 times
The base of the cam looks thicker than std is this a special cast billet
I had a cam snap right where it is thin at the cam gear
if it is, I never noticed that....
compare it to the one you have sitting on your shelf...
Cam has flat edges and not complete round shaft between the bearing faces, probably to clear the crank/rods.
Yes, it does. That is used to ensure the rods clear the cam... however there is nothing trick about that, its common knowledge that the cam can/should be grinded in that area if you are stroking to 82 or 84.
So no, that not the item I am making you guys look for.
Bad Ass Bob
Post by Bad Ass Bob »
Isnt the thrust side of the cam on the centre lobe ??????????????????B.A.B
NO, same place as stock, 1st bearing closest the cam gear
Ok No I fooled around long enough is that a 3 bolt conviguration that takes the bigger oil pump as it looks as if the cam gear is also diferent than a normal 3 bolt type :whip:
what is different about the cam gear? I think yo umay be onto something here.... (is that a big enough hint?)
It is a 3 bolt gear that uses the same oil pump as any late model case. For the bigger pump, the are built outwards, so you have to extend the bolts if the pump is bigger.
Tony Z wrote:Image
OK guys... look at this picture. Now pull out your stock cam and look closely.
And please dont comment about the profile of the cam lobes, thats not it either.
Ok last time we chated and you said it was a limited amount that was made of this specific item
Well could that be a inbetween cam gear meaning the angle of the gear is differint than stock looking at the pic on the PC it looks slightly angled not angled as much as a stock cam gear
:party: :party: :party: :party:
Finally
after 10 pages we have hit the mysterious item....
Yes that cam gear was made in a limited numebr a few years ago. From the story I was given, it cost the manufacturer too much to warrent selling them at a competitive price, so they stopped production.
The gear is in fact not at the same angle as a stock helical gear, but is pretty much half way between a stock angle and a straight cut gear. Meaning less side thrust, without the noise of a straight cut gear. And the thrust pressure is then further reduced by the full circle thrust bearing. Meaning that 4 times the spring pressure equates to roughly stock side thrust. Freeing up more HP (less than a straight cut) but still remaining quite (unlike most straight cuts)
Tony Z wrote:I expected better from you.... you'll kick yourself when you realise it... 1 item in specific that isnt found very often
You are damn well right about kicking your self and Never knew they made that and it is not easy to pick something up if you do not know about it but now we do
and not 10 pages only 5 back you ask the Q
F@ck at last
Bugger wrote:
F@ck at last
huh???????? 4th post page 1 and 1st post page 3
