Heres todays news...
so I wanted to get the doors back on but when I looked at the drivers side a post bottom I realised there was a bit of a problem. It seems as though the previous owner had trouble getting the repair panel to line up? so I'm left with a good 3/4mm short on the drip rail. Luckily its only the drivers side thats like that.
now I know the car will need filler but I wasnt happy about creating a drip rail out of it! :rolleyes: so I decided to take the long and annoying task of making a piece to extend it. First up I took some sheet metal and created a v shape..
Then it was squeezed shut to form a rounded profile in the vice..
I then spent what felt like forever cutting it down to fit and then tacked it in place..sorry about the pics, my cameras crap.
I then chopped it to length at the bottom, seam welded it front and back and ground it down. I then started the filler work. This was the first skim but you can see that the drip rail edge is now a lot better..
after many hours, and still needing some final work I threw on a coat of primer. I'm quite pleased with it considering..
Next up was to get the door hung, I ordered some stainless but philip head door screws (unlike the hex ones off ebay) from machine 7. Not exactly cheap for screws but I hate those hex type.
It's a fiddly job but the door went on ok and the hinge plates now work and tighten as they should. I still have slight sag in the door but there is play in the top hinge pin so I may take the time to fix that in the next few weeks. The door opens and closes ok though, just need to adjust the striker plates to get it uber smooth. Heres how it looks this eve with the door back on..
last but not least I trial fitted the front wing so I could scribe round it... as I'm sure you've noticed the front quarter is a mess so I wanted a line to start the bodywork from.
I'm going to get busy with the hammer in the morning and see if I can gently tap some of the dents out so I dont have to use quite as much filler..I'll no doubt update tomorrow night
