British Racing Green!!!
The 1976 Beetle Refurb with Type 4 Motor
- ViperR
- What model do you have?: 1976 Beetle
Re: The 1976 Beetle Refurb with Type 4 Motor
Got my paint for the front and rear suspension today. Yippee
And Then There Was a Bug!!!
- ViperR
I finally got a second selecta drop,
(Thanks Calooker)!!!!
Ready to start the conversion but,
Question:
I would like to know if I must cut off the bump stop or not, please advise ?
Question:
- 1972
Cut it off. It just gets in the way once its been lowwered.
or do it right... cut it off and weld it back in place where it would work. If it wasnt needed VW wouldnt have put it there. You just need to move it to where its needed now
- ViperR
- ViperR
Next up.....
Cleaning, de-greasing, primer & spray painting. Hopefully this will all be done by the end of the week.
nice action photos!!
- splitfan
- Has thanked: 46 times
- Been thanked: 26 times
Nice going, keep the pics coming !
- Farhaad
- Been thanked: 2 times
well done on the project so far. what paint did u use on the chasis and r u replacing the rubber matting that u removed from the chasis
- ViperR
Thanks, I used an Apu 106 anti corrosive primer with black 2k paint on the chasis.
Yes I will be replacing the matting with some sound barrier material.
- @ndrew
- What model do you have?: 1972 1600
Wow!!!
This is amazing work!!! Keep it up, you wont regret it!
- Phillip
- What model do you have?: 72 & 56 oval
Very nice,lot of effort in the chassis,cant whait to see the final result,
- ViperR
- Junior
- Pushrod
- What model do you have?: Had a 75 + 64 beetle
Wow looks great
I like your dog in the background
- ViperR
HEhehe, Thanks, he keeps his distance when I'm spraying. Must be the fumes.
