1914cc Type 1 customer engine build
- 4agedub
- Has thanked: 4 times
Re: 1914cc Type 1 customer engine build
It really does not help to skimp on the quality of the parts you use. Cheap and nasty parts will end up costing you double.
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
- 4agedub
Some progress at last. After almost a two month wait for the cylinder heads from CB they have finally arrived.
The cylinder heads are CB 044 mini wedge port with 42 / 38mm valves, opened for 94mm barrels and combustion chambers of 52cc. The combustion chamber size equates to 10,5:1 compression.
Last night we cleaned the combustion chambers and removed all the sharp edges.
The rockers are CB super race rockers 1.1:1 ratio.
- 4agedub
The piston pins with ally buttons fit really nice in the barrels, so by this weekend we should be able to finish assembly and get her fired up.
- 4agedub
- 4agedub
We fired her up on Saturday, it sounds real nice and responsive. The oil pressure is impressive, when cold it reaches 3 bar under cranking conditions.
The carbs on this engine is EMPI 44IDF's... now either they are crap or full of crap
, will take them off during the week to clean and try again.
- Been thanked: 98 times
More likely full of crap fitted a set earlier this year, I couldn't beleive what came out of them. I was warned before hand to clean them first, I did so, they ran Ok after some tinkering with the real cheap badly fitting linkage.
- 4agedub
These have run before, but was standing for about a year at the coast. So maybe they just need a proper clean.
You can see they are not webers... the quality is just not the same
- 4agedub
After cleaning the carbs properly it's running good now. After all this we decided to order a ultrasonic cleaner to make it easier in the future.
Cylinder heads have now been re torqued, valve clearances adjusted and dry sump pump installed. Now we wait for the crank pulleys and clutch then the engine can go into the speedster.
- 4agedub
We received the crank and alternator pulleys yesterday from engineering. All looks good, but as normal nothing will simply bolt on. The clearances on the keyway was a little light and we needed to machine the outside oil groove as well for a proper fit.
And so this build has come to the final parts, customer should take delivery this weekend to install the engine.
- Retrobug
- Has thanked: 15 times
- Been thanked: 32 times
That is one good looking motor!
Looks like you retained the stock style oil slinger on the crank pulley. I have found on a engine that revs fast and higher than 5000RPM the oil mist is going to make a mess of the engine compartment in short order, I get a sand seal fitted to prevent this from happening. My 50c
- 4agedub
All my engines still run the oil slinger without any issues. If the engine case is damaged, then we go the sand seal route.
- riaanj
- Has thanked: 6 times
- Been thanked: 41 times
Looks Awesome..
Any chance of a video clip, maybe when it's in the car, I'd love to hear it running..
Just keep on BUGGIN'
T6 Ranger 2.2TDCi D/Cab
307E Anglia panel-van
Honda CBR600RR
Honda CBR600F4
Honda CBR600RR
Honda CBR600F4
If you don't mind sharing, what did the final cost of this come to?
