This is the car the engine is going into:
We decided to build a small'ish capacity engine for reliability. So ended up with 69mm stroke with 94mm pistons. 1914cc.
Cb performance supplied us with all the goodies as usual
Wiseco 94mm short lightweight pistons with mahle barrels Straight cut camshaft gears Scat c55 camshaft with 1.1:1 cromoly rockers and solid shafts CB performance 69mm cromoly forged counter weighted crankshaft with H-beam connecting rods Auto linea ally bubble casing machined for 94mm barrels and 8mm cylinder head studs CB performance dry sump pump will take care of the engine oiling. A circuit racer absolutely depends on this.
